Abs/parking Brake
Old Jul 20, 2007 | 05:36 PM
slvrnblakattk's Avatar
Unhappy Abs/parking Brake
I have a 97 Z28 W/O traction control, the issue i'm having is when ever I start the car with parking brake up I get a flashing low trac light and an ABS INOP, when I let the parking brake down the low trac light goes out but the ABS INOP light remains on. I took a shot in the dark and R/R'ed the parking brake switch with on change in the gripe, for 3 bucks it was worth a shot. Looking for a little insight
Old Jul 21, 2007 | 02:47 PM
WS6NIGHTMARE's Avatar
For one reason or another your ABS block is not functioning. Mine is in the same state of "operation" but I havent figured it out yet. Come to think of it, I have tried too hard either.
Old Jul 22, 2007 | 10:32 AM
Most common cause of ABS INOP is a faulty wheel sensor or connection problem. But I think it can also be related to a problem with the center high mounted stoplight.
I'll move this to "Suspension, Chassis and Brakes" for you.
Old Jul 23, 2007 | 03:41 PM
I have removed and cleaned the rear ABS sensor, the parking brake cable adjustment looks good. As long as I start the car with the parking brake down the ABS system will be normal. How does the center high stoplight come into play??
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
