Identifying the trans in my car?
Old Jul 19, 2007 | 06:05 PM
chief455's Avatar
I just bought a 94 Formula
No paperwork - but the parts look to match the description.
Was told it has a Yank 700R4 and stall.
It's oon the lift and I read SS3800 and 05/03 on the convertor.
How do I tell which trans I have and if it's supposed to lock up?
Old Jul 19, 2007 | 10:17 PM
Performabuilt's Avatar
Supporting Vendor
Unless it was a switch from a manual its likley a 4l60e the 700r4 s cousin . I think I answered you on LS1TECH
Old Jul 20, 2007 | 04:51 PM
12SCNDZ's Avatar
It should be a 4L60E in a '94. Do you have a TV cable attatched to your throttle body for the transmission? The 700 used them. The 4L60E doesn't. Do you see a governor cover on the drivers side/rear on the transmission? This will be a large metal cap, near the rear of the transmission, just before the tailhousing. Is your case electrical plug on the drivers or passengers side? The 700 uses a smaller plug on the drivers side. The '60E uses a larger plug on the passengers side.
Frank
CPT
Old Jul 20, 2007 | 05:26 PM
chief455's Avatar
ok - I'll check your pointers Monday when the shop opens thank you!
Old Jul 23, 2007 | 01:13 PM
chief455's Avatar
large electric plug, passenger side above the pan
now we have to do some testing to see if lock up was eliminated on purpose - thanks
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
Zomie
Jul 25, 2002 07:52 AM
Zomie
Jul 22, 2002 07:43 AM
Zomie
Jul 22, 2002 03:34 AM
