Window Slides Back and Forth
Old Jul 15, 2007 | 02:21 AM
Oxygen454's Avatar
My car got broken into a little while ago and was fixed. The repair guy said I need a new plastic guide wheel so the window goes up properly. Chevy apparently wants $200 for the whole unit. Guide wheel and all. I just need the wheel. The window does not go up properly of course and has to be helped up. Would this make my window slide back and forth? Im guessing so?
Old Jul 15, 2007 | 08:14 PM
NovaTodd's Avatar
Try a company called CR Laurence. They carry the little parts like this. You will need to check the dimensions of the roller before you order as they are not like OReily's where you can look-up the part by application. They serve the glass industry, including automotive glass supplies.
Old Jul 15, 2007 | 08:29 PM
shock6906's Avatar
I went to a junkyard and got a new window. You can either replace the whole glass or just the rail at the bottom of it. Either way, it was 45 bucks for the window and the rail with the roller.
Old Jul 15, 2007 | 08:38 PM
Oxygen454's Avatar
I see, well Im not sure if we have those places up here in Canada but probably similar. Will have to look into it if not a friend of mine has a auto wreckers that he manages. Thanks for you help!
Old Jul 16, 2007 | 01:25 PM
Z28SORR's Avatar
Many chevy's have the same size rollers. Check with the salvage guy.
warmeck
Feb 2, 2015 12:44 AM
Fatdog2
Jan 24, 2015 12:08 AM
warmeck
Jan 20, 2015 10:29 PM
The Seer
Nov 20, 2014 06:32 AM
Snoman73
Nov 17, 2014 07:22 PM
