I broke the stud on my TA girdle!!! ---
Old Jul 4, 2007 | 12:26 PM
AlwaysCode390's Avatar
Exclamation I broke the stud on my TA girdle!!! ---
Where do I get a replacement?! I am talking about the bearing cap studs, I tightened it to 30lbs (it said 60 MAX in the instructions) and the damn thing just snapped right off (with the black nut) .... luckily its not leaking. They should replace this for free, or it should be cheap. I will just replace it when I do my 4.10 swap I guess.....
Thanks for the help/time (if you need pics let me know) ---
Old Jul 4, 2007 | 12:29 PM
mdacton's Avatar
your talking about the little preload stud with the lock nut?
I thought they were more like 5 ft lb.
Old Jul 4, 2007 | 01:44 PM
The actual stud is 60lbs max, and the lock nut is 5lbs .... I didnt even get a chance to get to the lock nut ---
Old Jul 4, 2007 | 03:59 PM
wrd1972's Avatar
The spec is 20" pounds of torque and 60" max.
Notice I said inches, not feet. Very little torque is required here.
You need a teeny tiny beam style torque wrench to properly do this.
Old Jul 4, 2007 | 04:15 PM
2001NBMZ28's Avatar
Thinking the same thing. 5 ft/lb = 60 in/lb. Contact them I'm sure they'll send/sell you some new ones.
Old Jul 4, 2007 | 04:35 PM
****, I just looked at the directions, your right, its 60in/lbs max, damn!!! ---
Old Jul 4, 2007 | 04:40 PM
mdacton's Avatar
big dummy
It happens
Old Jul 4, 2007 | 05:03 PM
Thats what I get for being in a hurry with a 6 pack in me, ****....now I have them torqued at 30lbs and I cant even back off the one side .... I hope I dont get "distorted bearing caps" .... screw it .... I have a complete rebuild kit I will install with the 4.10s ... I just hope it lasts that long, WOW , I am a big dummy ---
Old Jul 5, 2007 | 02:00 AM
revtime's Avatar
hey, it happens.
I went out and bought a nice Craftsman inch/lb torque wrench when I got my TA girdle thinking "I need an inch/lb torque wrench, never know when your going to need one of those"
The only thing I have ever used it for is the girdle.
Old Jul 5, 2007 | 01:26 PM
wrd1972's Avatar
Originally Posted by revtime
hey, it happens.
yeah there are few application that require inch pounds. The other time i use mine is to set pinion preload, very useful there.
Old Jul 6, 2007 | 05:39 PM
Thumbs up
hey, it happens.
Funny story, I love it . So far so good, no noise, leaks or smells so like I said "screw it" .... now I know better when I put my girdle on my SY and my 67 ' .... the 96 is just the TEST DUMMY :P ---
13qtr
Oct 28, 2016 08:11 PM
truecontr3
Oct 11, 2015 09:30 AM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
