ford 9 inch question
Old Jul 1, 2007 | 12:53 PM
ghost stripes's Avatar
i was told in order to get a 9 inch you had to find a car or truck(ford) below a 85 model well i went out and found 73 ltd and it doesnt look like a 9 inch .....whats the deal ?
Old Jul 1, 2007 | 01:37 PM
OBE1 95Z28's Avatar
Even if you found an original 9", it will need a lot of modifications to bolt up to a 4th Gen F-Body (torque arm mount, spring purches, LCA mounts, axle tubes shortened, rear brake mounting plates, etc).
Old Jul 1, 2007 | 03:57 PM
lethal93ta's Avatar
its not worth the cost to make one out of old parts, you can buy a 9 inch housing/axle kit for around 900-1000 bucks new, axles alone are around 400 shipped, then you need bearings 50-75 bucks, T bolts and the bearing retainer rings, till its all said and done you buy a used housing thats half rusted out your better off buying a moser kit.
Old Jul 1, 2007 | 05:11 PM
how much does a moser set up cost
Old Jul 1, 2007 | 05:15 PM
lethal93ta's Avatar
if all your looking for is a housing/axle there 900-1000 a complete bolt in kit is around 2000-2500 depending on what all you want on it.
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Dec 17, 2014 01:12 PM
ChrisFrez
Dec 15, 2014 03:09 PM
NewsBot
Dec 3, 2014 12:30 PM
