line pressure offset,shifts hard at low tps
Old Jul 1, 2007 | 12:23 PM
11secgen's Avatar
1-2 shift hard at low %tps,will this fix?(tunercat file inside)
my car shifts hard as hell at low %tps.if i lower the line pressure in the main line pressure0-64 mph table at the mph and % tps that the shift occurs, will it help?(edited title)
Old Jul 3, 2007 | 05:31 PM
11secgen's Avatar
my 1-2 shift is hard at all %tps.so what i did is lowerd the line pressure on the 0-64 mph table in the cells that were near 1-2 shift in the normal mode up/down shif point.that should lower the line pressure only around the mph and %tps where the shift takes place.i still want it to shift hard at higher %tps, but im sick of it snapping my neck at 1/4 throttle.im going to post my 0-64 line pressure tables if anyone could take a quick peak and let me know what you think.
Old Jul 3, 2007 | 05:36 PM
11secgen's Avatar
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
13 13 6 6 13 13 13 13 13 13 13 13 13 13 13 13 13
80 60 22 13 22 22 22 22 22 22 22 22 22 22 22 22 22
80 60 31 15 18 31 31 31 31 31 31 31 31 31 31 31 31
80 60 37 15 18 37 37 37 37 37 37 37 37 37 37 37 37
80 60 42 27 31 42 42 42 42 42 42 42 42 42 42 42 42
80 60 48 35 40 48 48 48 48 48 48 48 48 48 48 48 48
80 60 58 58 50 53 58 58 58 58 58 58 58 58 58 58 58
80 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64
80 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71 71
80 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75
80 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77
80 80 80 80 80 80 80 80 80 80 80 80 80 80 80 80 80
86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86 86
90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90
evertything was stock before, i went with about 2/3rds of the original numbers around the tps% and mph in the cells surrounding where the 1-2 shift happens.
Old Jul 3, 2007 | 05:38 PM
11secgen's Avatar
heres my normal mode up/down shift points.
11 20 34 10 10 30
11 21 35 10 18 30
12 22 36 10 18 30
13 24 38 10 18 30
13 31 43 10 18 30
14 36 53 10 18 30
15 41 58 10 18 30
19 47 67 10 19 33
24 50 74 10 21 37
29 53 82 10 26 41
31 59 90 10 30 46
34 64 107 10 35 53
35 66 126 10 39 64
35 66 126 10 39 118
35 69 126 10 39 118
36 73 126 31 39 118
36 73 126 31 67 118
i lowered the mph for the 1-2 shift at6%tps-43%tps to keep it from ''hangging'' in first for so long when going slow havent tried this tune yet, so if anything looks wrong let me know.thanks!
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
