moser 12-bolt wheel studs
Old Jun 27, 2007 | 11:12 PM
IEAT50Z's Avatar
Ok so I have a moser 12-bolt rear end and I plan on switching to welds, are the wheel studs long enough and safe under race conditions for this? do I need longer studs?
Thanks!
Old Jun 27, 2007 | 11:18 PM
I have 3" studs with the Welds, and they just barely poke out of the ends of the lugs. Not a Moser, but a Strange 12-bolt with 1/2" screw-in studs. You will need at least 2-3/4".
Old Jun 27, 2007 | 11:57 PM
IEAT50Z's Avatar
Thanks, is there a specific jegs or summit part number for the ones that you used?
what size are the factory ones? I guess 1/2.
Old Jun 28, 2007 | 12:02 AM
IEAT50Z's Avatar
070-100-7713
I wonder if those would work?
509'' Knurl Wheel Studs
Late GM (F-body, Corvette)
12mm x 1.5
3.250" long
5 per package
Do the axles need to be removed to replace the studs?
Old Jun 29, 2007 | 10:33 AM
IEAT50Z's Avatar
bump?
Old Jun 29, 2007 | 05:19 PM
Does your Moser have screw-in studs or knurled studs? The Strange came standard with two sets of screw in holes in the axle flanges - 12mm and 1/2". I don't know it the screw-in studs are standard of optional on the Moser.
3-1/2" studs will stick out at least 3/4" beyond the lugs. It will obviously cause a problem if you ever put stock wheels on the car, with the studs sticking wayyyyyy out of the lugs.
Old Jul 2, 2007 | 09:24 AM
IEAT50Z's Avatar
I will have to check on that then...I don't plan on running street rims on the car anymore, infact I only have the fronts because skinny's aren't the safest thing in the world.
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
wytblur
Mar 2, 2003 03:40 PM
Ken95Z28
Sep 15, 2002 12:37 AM
wytblur
Aug 5, 2002 02:10 PM
