373 manual rearend in a 95 camaro auto
Old Jun 24, 2007 | 12:21 PM
lt1loudmouth07
Guest
Posts: n/a
Will a manual rearend from a 95 z28 work in a 95 z28 auto. i was hearing that the manual one has a 3 channel abs and the auto has a 4 channel can someone please help me out if not would there be any way i can get it to work
Old Jun 24, 2007 | 12:47 PM
11secgen's Avatar
im pretty sure both have 4 chan. abs. a manual rear would come with 3.42 stock and auto would be 3.23.maybe somebody else could confirm the 3-4 chan abs thing?
Old Jun 24, 2007 | 01:03 PM
karpetcm5's Avatar
Yes wont matter if its manual or auto, if you have the 2:73's to start off with and your putting in the 3:73's then you would have the rear end shop put more shims or something i forgot what they do, but if your car came with the 3:23's and your putting in the 3:73's its a direct swap. I had 2:73's in my 6speed and went to 4:10's makes a world of difference.
Old Jun 24, 2007 | 02:06 PM
lt1loudmouth07
Guest
Posts: n/a
rearend
Yea but i have a stock a4 273 right now. But i want to put in a rearend that came out of a manuel with 373's would that work in a auto the guy said it would not because its a 3 channel abs and not a 4 channel but i would like to make it work any suggestions
Old Jun 24, 2007 | 02:07 PM
lt1loudmouth07
Guest
Posts: n/a
rear
also the guy had 373's put in his rearend thats why i want it
Old Jun 25, 2007 | 12:02 AM
revtime's Avatar
Wouldn't this depend on if one of the cars had traction control?
If both cars did not have traction control then you could swap the rears back and forth all day long and not have any issues.
The only thing that comes to mind is programming the PCM for the gear change.
Old Jun 25, 2007 | 01:12 AM
Jared 3870's Avatar
I swapped a four channel into my non TCS car. It took a little creativity to reconfigure the brake lines to a 3 channel setup, but it performs flawlessly now.
Old Jun 25, 2007 | 04:00 AM
lt1loudmouth07
Guest
Posts: n/a
rear
Awesome thanks guys, Yea i have tunercats i can program that myself. How do you set a 3 channel up to be a 4
Old Jun 25, 2007 | 08:09 AM
Tunercat has nothing to do with the brake system. The ABS uses a separate computer that Tunercat does not talk to.
What you need to find out is if both cars have traction control or not. If both do (or do not) have it, then you have no problem.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
cmsmith
Jan 5, 2015 07:04 AM
ChrisFrez
Jan 4, 2015 08:43 AM
