How much boost can you run with stock motor & 54cc LT1 heads?
Old Nov 28, 2002 | 12:03 PM
bunker's Avatar
Lightbulb How much boost can you run with stock motor & 54cc LT1 heads?
Just wondering about going blower with my heads, 54cc LT1 heads, 6lb you guys think will be fine? What is ussually the compression ratio with 54cc heads & stock LT1 motor & Fel-pro 1074 gaskets? LMK thanx guys. I know guys run 8lb on stock motors with no probs but stock heads are like 68 cc, thanx LMK guys.
Old Nov 28, 2002 | 12:06 PM
AHARTZ28's Avatar
6lbs max!
Old Nov 28, 2002 | 01:21 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I wouldn't run any boost on a stock LT1. It's not a matter of IF, but WHEN it's going to break.
Old Nov 28, 2002 | 04:00 PM
funina91ss's Avatar
IMO build the bottom end then get a blower .I thought all LT1 heads were 54cc???
Old Nov 28, 2002 | 04:08 PM
OneFlyn95z28's Avatar
6#MAX!
STILL it will be "When" it breaks not if
Still trying to beat my N/A car eh?
Old Nov 28, 2002 | 04:28 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
How about none at all in your case. Stock LT1 heads are 58cc. Your down at 54cc so your about 11to1 now. Time to get blower pistons.
Old Nov 28, 2002 | 05:50 PM
Roadmaster's Avatar
LT1 pistons just hate boost.... Again nothing really over 6psi. One of the Aftercooled Vortech kits is cool and I assume cooling the incoming air will lower the risk of detonation.
Good luck
Dustin
Old Nov 29, 2002 | 02:32 AM
bunker's Avatar
Thanx guys, don't worry flyingZ I'll show you what's up
Old Nov 29, 2002 | 07:42 AM
Smoke T/A's Avatar
Talking
I bet those heads kick ***!
Old Nov 29, 2002 | 09:56 AM
kmook's Avatar
Advanced Tech Moderator
Well i think you have some figures smudged up
First off stock LT1 heads are around 58cc not 68. With 58cc, stock engine, gaskets, etc it comes to 10.52:1 c/r.
When you change the figures to 54cc and a felpro 1074 gasket you now have about 11.36:1 c/r.
IMO much to high to safely run boost period.
Old Nov 29, 2002 | 08:08 PM
bunker's Avatar
I'll settle for stock head gaskets when I get the blower, I think that should be ok? thanx smoke T/A !
Old Jun 3, 2003 | 01:46 AM
bunker's Avatar
You are wrong KMOOK, stock heads are 54-56CC tops, compression is 10.9:1 trust me, I CC'd several stock heads some are 54cc dead on stock, mine were 55.6 or so, now they are 54cc exactly, .006 milling = to 1 cc, I milled .010 which = to minus 1.6cc, they went from 55.6 to 54 cc.
Old Jun 3, 2003 | 03:08 AM
delbuort's Avatar
I'm not an expert on boost but I've asked the same question before and the response that I got was 4lbs max. But, like I said, I really have no idea. You might have better luck by posting this in the forced induction section.
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
NewsBot
Dec 28, 2014 06:20 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
