rpm limitations on stock pcm
Old Jun 5, 2007 | 11:31 PM
crazydavez28's Avatar
i've heard that the stock pcm will only support rpms up to 7200 is there any way to let it go higher b/c i hate it when everything sounds so awesome and then it cuts out cuz the computer
Old Jun 6, 2007 | 06:32 AM
GetaZforgetGT's Avatar
My understanding is that the 7200 rpm limit is a function of the relatively slow processeing power of the OBD1 system.
It can't make adjustment fast enough to support the engine above that RPM.
Old Jun 6, 2007 | 10:32 AM
Kyle@CSS's Avatar
I don't know of many LT1s turning that hard with a Factory PCM Or intake. If your car needs to turn that hard I would upgrade to a aftermarket system. Above 7200 the PCM will just read off the last input on the fuel and timing tables.
Old Jun 6, 2007 | 09:12 PM
well i have the cc502 ported heads and intake. the bottom end is all forged w/ h-beams and i have the 918's.
yesterday when i was just out making noise i was running it to about 6500 and it was doin fine but when the tach hit 7k it cut out and let off a puff of black smoke out the exhaust. once the rpms go back under 7k it cuts back in and runs fine. is this a rev limiter? cuz i thought i didn't have one
what aftermarket pcms are good for lt1?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
