Foglights (not sure if it belongs here)
Old May 25, 2007 | 08:48 PM
unvc92camarors's Avatar
Just need to know where I can pick up a cheap, new foglight. I know Jason Cromer used to be known to get stuff. Is he still around? Also, is gmpartsdirect.com still quite bad about getting stuff out?
Old May 25, 2007 | 11:47 PM
'94 Bad A Z28's Avatar
Just replace the bulb in your current fogs and put a clear, or smoked whatever you want, cover on yours... because you will just be even more pissed when your new fog light cracks again. I'm just assuming that you have a cracked/shattered fog light, right?
Old May 26, 2007 | 12:23 AM
n2ceptor's Avatar
HL74322 FF75 Driving Lamp Kit $80.31
http://www.rallylights.com/hella/ff075.asp
Stock driving lights cost around 100.00... Cheap, maybe a salvage yard... Most replace with hella..
You can find out more in the Appearance Section...
Old May 26, 2007 | 11:38 AM
Bud M's Avatar
Old May 26, 2007 | 12:07 PM
No, it's just burnt out. I know it's a pain to replace just the bulb but I may just try that. Any in the junkyard seem to have been wrecked on the front, therefore damaging the foglights in the process.
Thanks for the suggestions though guys.
Old May 26, 2007 | 12:43 PM
MARKTHOMASBRAND's Avatar
Replacing the foglamp bulb takes about 10 minutes, tops .
Just a case of removing the spring-loaded screw at the top and then easing out the two plastic rivets at each side,with a small flat-bladed screwdriver,which the lamp unit pivots on.
All the best,Mark.
Old May 26, 2007 | 07:11 PM
TheV6Bird's Avatar
All the best,Mark.
http://www.bfranker.badz28.com/fbody/fogs.htm
It shows some step by step pictures on how to fix 93-97 fog lights.
Old May 28, 2007 | 11:48 AM
Ahhh, thank you. I've seen his guide for replacing the whole fog lamp and figured that was all he had. This will work out very nicely. Only thing is I've done the whole fog lamp replacement before and it's such a PITA. Oh well...
Thanks again. This definately helped.
Old Jun 10, 2007 | 05:04 PM
Just wanted to say thanks again. I replaced it in about 15-20 minutes today (needle nose pliers weren't long enough, but I made it work). Thanks guys for your help, and Brent if you read this, thanks for the write up.
Old Jun 10, 2007 | 08:12 PM
n2ceptor's Avatar
Glad to see it worked out for you.....
PROJECT X
Apr 17, 2015 12:13 AM
MeefZ28
Feb 8, 2003 09:40 PM
ishmuff
Nov 25, 2002 01:39 AM
nothingeined
Nov 6, 2002 06:18 AM
nothingeined
Oct 15, 2002 11:34 PM
