A/C compressor... clutch or no clutch?
Old May 21, 2007 | 05:56 AM
SS RRR's Avatar
Going to buy a re-manufactured A/C compressor and according to www.partsamerica.com there is an option to buy one w/ or w/out a clutch?
Am I wrong to think the 4th gen f-body compressors have a clutch?
Old May 21, 2007 | 06:18 AM
Asylist's Avatar
just about every compressor has a clutch, otherwise they would be pumping any time the engine is running. Technically you can swap the clutch over from your existing unit if it's still good, but you need a special puller to get it off and being a wear item you might as well replace the whole thing while you're there.
Old May 21, 2007 | 12:35 PM
96m6lt1's Avatar
your best bet is to buy the comp.with the clutch cause the other one is old and will eventually go bad as well,i have been told that you replace both at the same time so thats what i have done!
Old May 21, 2007 | 03:47 PM
SS RRR's Avatar
Thank you both.
magman
Apr 15, 2016 03:08 AM
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
