True duals and cats?
Old May 14, 2007 | 01:40 PM
Soccerbum21's Avatar
is there any way i could run cats on a true dual setup. i am in the process of deciding if i am going to go the AS&M mid length 1-3/4 headers with an electric cutout and stock cat with my existing cat back.
or...
jet hot long tubes, true duals setup, under the axle out the rear. but somehow i need to figure out where the cat(s) would fit into the equation.
i'm still in the process of reading the million pages of true duals in the sticky section of LS1tech. but if anyone has this kind of setup, lemme know! thanks
Old May 15, 2007 | 02:17 PM
Mikie's Avatar
You can put Cats on the TD setup. Just have the Muffler shop cut the pipes and put them in-line. I have seen some guys run under the axle exhaust with a solid axle, but I would not recomend doing it. Very hard to jack up the car and also very low hanging pipes.
Old May 15, 2007 | 02:37 PM
shock6906's Avatar
I saw a guy do true duals under the axle, but he had 3 bolt flanges in front of the axle so he could remove the rear section of the exhaust if it was getting in your way. It was a pretty good idea if you ask me.
Old May 15, 2007 | 02:53 PM
Mikie's Avatar
Now thats smart! Good advice Shock.
Definitely something to consider. Also alot easier than swapping to IRS...lol
Old May 15, 2007 | 03:22 PM
Greed4Speed's Avatar
There are pics of set ups like that on LS1tech.
Old May 15, 2007 | 04:41 PM
shock6906's Avatar
He was on this board. He posted pictures in the LT-1 section, I believe. I looked through earlier but didn't find anything. Perhaps a callout could turn him up.
Old May 16, 2007 | 08:30 PM
like i said, i went through all those pics and such on LS1 tech, and it seems most people just ditch the cats
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
Aug 3, 2015 08:42 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Catmaigne
Jul 14, 2015 05:17 PM
