Strengthening the 10 Bolt.... Ideas?
Old May 13, 2007 | 09:54 PM
1LESSZ28's Avatar
I am going with a Ratech solid spacer as opposed to the crush sleeve unless anyone knows good reason not to. anyone know a link to an install for this? I have been told it is fairly easy and does not require resetting the grears?
Also, after doing the solid spacer would I still benefit from a girdle and stud kit?
How much rear GM additive should I add when I change my fluid?
any other cheap things that your slightly above average diy person can replace in the rearend?
Old May 14, 2007 | 08:14 AM
teke184's Avatar
girdle and stud kit will help
4oz of additive i beleive is all that is needed
the higher the gear ratio (numerically that is...ie...4.10) the smaller the teeth on the ring, therefor the weaker.
Old May 15, 2007 | 09:32 PM
1LESSZ28's Avatar
anyone have any info on the ratech solid spacer (to replace the crush sleeve) install and/or its effectiveness?
Girrrrl
Aug 20, 2015 06:17 AM
TGGodfrey
Aug 18, 2015 06:08 PM
Rittmeister
Aug 7, 2015 01:13 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
asilomar244
Jul 12, 2015 05:53 AM
