dtc codes
Old May 12, 2007 | 02:43 PM
Garcia95's Avatar
dtc codes
my car was missing and i scanned it it gavevme a code for the cam sensor so i replaces the sensor and the problem continued any ideas on what it could be i was thinkoing it was the connector wires but i would like some ideas or possibilitys on this from someone ells. 95 camaro 3.4L auto.
Old May 13, 2007 | 03:00 PM
chevycamarosaturn's Avatar
remove your cam sensor look to see if the magnet is still on the cam gear if it is missing you need to replase it.
I worked for buick and I did a lot of them.
Old May 13, 2007 | 05:55 PM
Garcia95's Avatar
so how do i check the sensor i remove it then look in to see if i see a magnet is on the gear. how big is it is it hard to replace? just want to know before i dig in the vehicle
Old May 13, 2007 | 07:00 PM
You will have to remove the sensor and with a mirror look into the hole where the sensor was and rotate the crank byhand and inspect the cam gear as it rotates there is a hole where a magnet in a black plastic clip is push into a hole on the cam gear, The magnets come loose and get chewed up by the moving part. so you will see just the hole in the cam gear or the plastic housing sometimes will still be there but the magnet is gone.
if that is it, you will have to remove the cam gear to replace the magnet.
A little bit of a big job but not to bad.
Old May 14, 2007 | 03:52 PM
Garcia95's Avatar
kool sounds a bit dificult but im sure i can tackel that kind of job myself so thanks for that it sure have me an idea of that i should be looking for cause i was a bit lost with the magnet thing and all.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
