How Bad Is This. Gear Shreds
Old May 9, 2007 | 10:45 PM
Killaz's Avatar
wELL GUYS FOUND THIS WHEN WE OPENED MY BOTHERS REAR END ON HIS 2002 Z28. HOW BAD IS THIS?
Old May 10, 2007 | 12:54 PM
ConElite's Avatar
I cant make out what that is at all. Its blurry
Old May 10, 2007 | 01:19 PM
Killaz's Avatar
alot of fine shreds of metal
Old May 11, 2007 | 08:48 AM
FirstYrLS1Z's Avatar
It's OK. Z28s have a Auburn limited slip which is an steel to steel cone clutch and as the cones' spiral grooves wear,which is natural,the metal goes into suspension in the gear lube and eventually get collected by the magnet.That picture shows a very minor amount compared to the large amounts that i've seen/encountered.If you're concerned,change the fluid periodically to keep the fluid slurry of metal particals from acting upon the bearings and races.
Old May 15, 2007 | 07:27 PM
Capn Pete's Avatar
As long as it's mostly a "paste" consistancy, and it's not large "chunks", then everything appears totally normal .
Old May 15, 2007 | 08:19 PM
FryedClutch's Avatar
when you ca pick little endgear teeth off the magnet then you know there is something wrong lol
honestly looks Ok to me
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Feb 15, 2015 07:49 AM
mattszm6
Dec 14, 2014 07:09 AM
Noenav
Dec 6, 2014 07:35 PM
Jul 4, 2005 05:00 PM
