M6 Tranny Fluid
Old Apr 29, 2007 | 06:54 AM
solarofthesix
Guest
Posts: n/a
M6 Tranny Fluid
ok so i had the tranny out to replace my clutch and swapping to a hurst short shift. I noticed there was only a little bit of residue worth of fluid that was visible. how much is supposed to be in there? should i bebael to see or not?
95z28 m6
Old Apr 29, 2007 | 12:09 PM
Bayer-Z28's Avatar
The fill plug is on the pass side. When you remove the female 3/8" square plug 1/2 way up on the side of the trans, you should be able to feel it when you stick a finger in there.
FWIW, it takes about 3.6-4 qts of dex III or RP SyncroMax.
I am unsure as to what you mean when you say 'see the fluid'. Looking in the fill hole?
Old Apr 30, 2007 | 07:08 AM
Capn Pete's Avatar
I think you mean there was only a little bit of fluid laying in around where the shifter goes (once you pulled the shifter off), correct?? That's ok . The bulk of the fluid is down in the tranny, and circulates around while it's running.
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
