Hot headers?
Old Apr 23, 2007 | 02:28 PM
phoenix1987's Avatar
Hot headers?
My drivers side header is hot almost right away after I start the car, while thew passenger side remains warm. Is this normal? I want to make sure before I drive the car around town.
Old Apr 23, 2007 | 02:44 PM
SSpdDmon's Avatar
If you're worried about a problem between the two sides, pull your plugs. They will tell the true story about what's happening inside your motor.
Old Apr 23, 2007 | 04:27 PM
Plugs are fine. Car runs good. Maybe it just needs a tune. TR230/224 cam.
Old Apr 24, 2007 | 12:27 AM
SSpdDmon's Avatar
You're driving around with that cam on a stock tune? I hope you haven't (or at least don't) floor it at all. Besides the timing being off, your AFR is most likely off as well. I'd tread lightly until you get a tune...
Old Apr 24, 2007 | 07:47 AM
Chrome383Z's Avatar
Plugs might be fine, but you can usually tell if they look like it's been running lean or rich.
Although, it takes a trained eye. Since the advent of A/F meters and whatnot sparkplug reading isn't as prominent as it used to be.
I would strongly suggest a tune.
Old Apr 24, 2007 | 09:25 AM
SSpdDmon's Avatar
Originally Posted by Chrome383Z
I like your sig...
Old Apr 24, 2007 | 02:04 PM
Capn Pete's Avatar
The A/F on my car has leaned out just by the addition of the LT headers ... I imagine a bigger cam would only make that more dramatic . FWIW, my car ran ~13.0:1 A/F on the dyno, stock. After just the headers, the A/F was around ~13.5:1.
HarleyZ28
Oct 5, 2015 06:23 AM
Drtryder
Apr 22, 2015 04:17 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
