clutch hydralic line removal tool
Old Apr 23, 2007 | 01:20 PM
Wicked 97TA's Avatar
Does anyone know where I can buy a good clutch hydralic line removal tool to get the hydralic line lose from my slave cylinder?
Old Apr 23, 2007 | 08:39 PM
deadcamaroz28's Avatar
Just use a pick tool to push the roll pin out the other side. Then just grab the roll pin with plliars and pull it out. Then the line will come right out
Old Apr 26, 2007 | 02:00 PM
Is that for an LT1 or LS1 car? I've got an LS1.
Old Apr 26, 2007 | 03:18 PM
ConElite's Avatar
Alright, All your going to see is the line going into the Transmission one the Drive side. What you need is 2 flat head screwdrivers. There is a white Washer looking thing. You have to push that into the line towards the Transmissing. Once the White Washer is pretty much pushed in all the way, Push in the Steel breaded line and then pull it out and it should could right out. Im going to warn you now, Its a pain in the butt to push that line back in. Why are you changing the line?
Old Apr 27, 2007 | 01:36 PM
I'm trying to change the whole clutch master cylinder.
Old Apr 27, 2007 | 02:25 PM
ConElite's Avatar
Oh alright... Yeah its not to hard to remove if you know what your doing.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
