car has the shakes...
Old Apr 23, 2007 | 10:11 AM
ZL1modified's Avatar
Unhappy car has the shakes...
the car only vibrates hard from 70-80 at WOT or when accelerating very quickly (rattles the change in my console pretty bad)...
If i am chugging along between 70-80 the car is fine...(no vibration felt)
The wierd thing is that i went from 3:73's to 3:42's and the vibration stayed consistant at 70-80...
would low gear oil do this? because my rear is leaking pretty bad... (from the front and rear)...
i have replaced: rear rotors, driveshaft, set the pinion angle, transmission, damper pulley, rearends, u-joints, spindles, front rotors, hubs, mounts, had the wheels balanced... i pretty much did everything and i still have this GD vibration...
i'm running out of ideas... and i'm wondering if bad springs could cause this? i am frustrated and clueless...
can someone either help me or refer me to a drivetrain specialist... (in the SW PA area)
thank you
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
