Tires not spinning?!
Old Apr 22, 2007 | 10:16 PM
YoungSS's Avatar
I have a Moser 9" locker and 4.30 gears with mickey tompsons on back. One tire wants to spin while the other starts then stops. what could this be?
Thanks for any help!
Old Apr 24, 2007 | 03:00 PM
YoungSS's Avatar
no one can help?
Old Apr 24, 2007 | 08:21 PM
danhr's Avatar
your locker's messed up? the second one tires slips and the other one doesn't, your locker should lock both axles and they should both spin.
Old Apr 24, 2007 | 08:28 PM
93v8clone's Avatar
did ya putt the slip additive in it and go blow figure 8;s to get all fluid and additive throught
Old Apr 24, 2007 | 10:54 PM
YoungSS's Avatar
The setup has less than 5K miles on it. This has never happened before. could the brakes be grabbing too hard all of a sudden and cause it to come unlocked?
Old Apr 25, 2007 | 08:22 AM
danhr's Avatar
why would you put limited slip additive into a locker?
Did you get rid of your abs unit? did your car originally have 3 or 4 channel abs? If you make a "signature" or a "sig" with a quick description of your car and what you have done to it, it would make it a lot easier to help you.
Old Apr 25, 2007 | 02:16 PM
YoungSS's Avatar
Yes i did keep the ABS. i believe 4 channel. I don't know anything about the addiive stuff.
Old Apr 25, 2007 | 07:15 PM
danhr's Avatar
What year is your car?
The additive is a limited slip additive that you put in limited slip differentials (which you do not have) so you don't need it.
Old Apr 25, 2007 | 07:21 PM
93v8clone's Avatar
ahhhh i only half read it didnt see it was a locker
Old Apr 25, 2007 | 09:15 PM
YoungSS's Avatar
2002 Camaro SS
Old Apr 26, 2007 | 11:14 AM
danhr's Avatar
check your abs stuff..... that's the only thing I can think of
Old Apr 26, 2007 | 09:25 PM
HodgesZ28's Avatar
Is it making any noise? This may be a dumb ? but have you actually seen the inside of the rear? Maybe it's not a locker but a tru-trac or a limited slip and its busted.....just my .02
Old Apr 26, 2007 | 10:12 PM
YoungSS's Avatar
it's a locker for sure, you can hear it lock when you touch the throttle. It's a new peice from moser so i sure hope they wouldn't make that mistake. i think i'm going to take my ABS stuff off.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
