Battery mount?
Old Apr 14, 2007 | 01:50 PM
plusandrew's Avatar
Battery mount?
So, I was checking my fluid levels the other day and I noticed there was a bunch of crusted gunk by my battery, so I went to flake it off and then I noticed...
my battery is just sitting loose in my engine bay without a mounting bracket.
anyone know the gm part# for a battery mount or any way I can secure it?
(99 v6 camaro)
Old Apr 14, 2007 | 02:59 PM
Dave89IROC's Avatar
battery hold-down and tray are part if the coolant bottle, inexpensive at the dealer
edit
here's the GM part number
10402687
GM list is $40, call jason or dal and get it cheaper
or look for used ones
Old Apr 14, 2007 | 04:13 PM
MustangEater82's Avatar
skip the GM part, its a POS and a paint to change...
for like $5 at home depot you can get a strap with pre-drilled holes in it. Just hookd it up in the factory hold down clamp bolt, and then have it go up and over the battery, then bolt into the rear mount for the headlight.
Old Apr 14, 2007 | 06:05 PM
OBE1 95Z28's Avatar
I agree with the post above, the factory design is poor and it will break again after you replace the coolant tank/battery tray. Here's a link to an inexpensive fix that my friend created and we both use: http://members.aol.com/blownf1/batttray.html
Old Apr 14, 2007 | 07:40 PM
plusandrew's Avatar
I'd rather use a stock battery mount than some 'inventive creation' to hold my battery in place.
thx for the part number
Old Apr 15, 2007 | 10:34 AM
I got a PVC coated generic steel clamp at an auto parts store that replaces the stock plastic wedge, and ran a bolt completely through the base and added a nut, rather than use the threads in the battery tray. Battery is solid as a rock, and its been that way for 7 years.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
silvermansteve
Mar 4, 2015 05:02 PM
