Hooking up powerand ground for gauges
Old Apr 12, 2007 | 12:48 PM
94_camm's Avatar
Ok iam installing 3 gauges and my tach..can i hook up all of the power wires together and connect it to one power source?
Old Apr 12, 2007 | 05:21 PM
Yes. Combine the ground wires and find a good screw or bolt under the dash (in chassis metal) to attach them to. Combine the +12V wires and run them to the "IGN" terminal in the fuse block at the end of the dash. You might want to keep the +12V for the lights separate, and run them to the fuse that powers the dash lights, or to the output of the headlight switch or the dash light dimmer switch. That way, the gauges only light up when your lights are on, and you can dim them if you want to.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Knightscrapper
Feb 4, 2016 10:25 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
sdn1997rs
Dec 30, 2014 08:30 AM
