Fidanza Flywheel Balancing?
Old Apr 11, 2007 | 03:21 AM
TwEaKeDSS's Avatar
Anyone know if the LT1 Fidanza Aluminum flywheels come Neutral Balanced? I noticed that there was a removable weight on the back so I am assuming that they are setup to work with the STOCK LT1 setup which is external balanced. I need to know because I am running an internal balanced setup so if it just means that I have to remove the weight on the back of the flywheel then I would rather do that than have to get it balanced.
Old Apr 11, 2007 | 04:08 AM
Zepher's Avatar
A friend of mine got the LT1 lightened Fidanza flywheel and it needed to be balanced. I believe there was a slip of paper in the box mentioning this.
Cost $35 at local machine shop here to balance it.
Old Apr 11, 2007 | 09:42 PM
TwEaKeDSS's Avatar
I called Fidanza today. They said to just remove the bolt in weight that comes on the flywheel and that will make it neutral balanced.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
