96 ta rear
Old Apr 5, 2007 | 11:59 AM
cornbread's Avatar
96 ta rear
ok guys i have noticed that my posi is not working as well as it should. i just bought the car and new to fbodies. i have a few questions for my 96 lt1 ta
1.) what size is the rear?
2.) can the posi be rebuilt?
3.) what type of posi is it
4.) what gears are factory for my 6 speed car
thanks guys i have tried the search but only finding ls1 cars
Old Apr 5, 2007 | 01:23 PM
Jared 3870's Avatar
1) 7-5/8 inches
2) Probably be better off getting a new unit, or if you don't mind used, just picking up a whole new rear from a salvage yard.
3) Auburn Differential (clutch/spring type, as opposed to the LS1 rears which use Zex-Torsens, a worm gear type).
4) Factory M6 gears for your year should be 3.23. I think the LS1 cars were the only ones with 3.42s stock. Check your RPO codes, it'll be GU5 I believe.
Old Apr 5, 2007 | 03:32 PM
2000GTP's Avatar
I'm pretty sure all 4th gens with the M6 had 3.42 gears.
Old Apr 5, 2007 | 03:41 PM
TobyZ28's Avatar
3.23 were for A4's with the GU5 (i think its Gu5 at least) rpo code.
3.42's were standard for m6's
Old Apr 5, 2007 | 04:20 PM
cornbread's Avatar
is the posi rebuildable? i am doing bearings anyway so i thought i might do that as well
Old Apr 5, 2007 | 09:10 PM
Jared 3870's Avatar
Thanks GTP and Toby, couldn't recall if the 3.42s were available with the LT1s.
Old Apr 5, 2007 | 10:47 PM
eagleknight97's Avatar
No, 3.23's were stock with M6's, 3.42's were the GU6 option, the performance axle option.
Old Apr 7, 2007 | 01:36 AM
lbrowne's Avatar
First I heard of that on a 96...
Old Apr 7, 2007 | 02:02 PM
TobyZ28's Avatar
3.42's were standard for m6's. Perhaps there was a year where that was not the case (93s?), but for the rest of the V8 M6's it should be 3.42... 94+ im quite sure of.
Old Apr 7, 2007 | 02:26 PM
Hmmm, guess im wrong. I thought the M6's also had 2 rear choices, just like the autos, guess not. Sorry
Old Apr 7, 2007 | 02:34 PM
cornbread's Avatar
Is the posi rebuildable? i need to know so i can get the stuff i need. it goes in the shop next week
Old Apr 7, 2007 | 02:47 PM
TobyZ28's Avatar
yes
Old Apr 8, 2007 | 11:47 AM
metallicsniper's Avatar
hey i am willing to sell you my rear from my 2000 Z28 M6. only has 64k on the rear. i am getting a new rear in the next few weeks. So i will have no use for it. all you have to do is change the backing plates, so you can mount your brakes to it. I will sell it kindof cheap if you let me keep the backing plate which are of no use to you. PM me if your interested.
Old Apr 8, 2007 | 07:54 PM
cornbread's Avatar
is there a part number for the rebuild kit?
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
