What does LS-1 stand for?
Old Nov 24, 2002 | 05:32 PM
Tripp's Avatar
Question What does LS-1 stand for?
does LS-1 stand for anything?
Old Nov 24, 2002 | 06:35 PM
SpecForceZ28's Avatar
It stands for your engine code, in fact, all the options your car came with would be posted as a code, on a sticker on your driver side door. LS1 means you have the 5.7L V8, same engine in the C5 corvettes.
Old Nov 24, 2002 | 06:39 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
"LS1", is a GM factory code for the type of engine you have. Some other engine codes are: LT1-346ci cast iron block, aluminum heads, LT4-454ci, 425HP (I think). More codes of engines, even though I do not know the specs are, ZR1,L89,LS4- 396cu, 375HP.
Hope this helps you out in some way.
SteveC
Old Nov 24, 2002 | 07:13 PM
PhantomTA's Avatar
Moderator
Your way off on what Code is what engine..
I MEAN WAY OFF!!!
anyways..
it just an engine code.. nothing else
Old Nov 24, 2002 | 09:44 PM
SS_Thunder's Avatar
LT4, 454 CI????
Old Nov 24, 2002 | 11:12 PM
LS4? I think its LS6, and LT4?
Old Nov 24, 2002 | 11:28 PM
Tripp's Avatar
ls-1
ls-1
i know i have the same engine as a c5 and what not. what i ment to say what does the "L" and the "S" stand for?
well obviously it dosent mean Lingenfelter. are they initials for anything?
Old Nov 24, 2002 | 11:35 PM
2002Z28SSConv's Avatar
doubtful
Old Nov 24, 2002 | 11:58 PM
nope, none of the codes on the camaro's can be put that way, at least I don't think
Old Nov 25, 2002 | 07:19 AM
PhantomTA's Avatar
Moderator
Re: ls-1
Originally posted by Tripp
ls-1
it means nothing.. its a code...
Victor Lamb
Aug 26, 2017 02:52 PM
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
Boss002
Jul 9, 2015 03:33 PM
fastenuff
Sep 6, 2002 10:57 PM
