recharging AC system
Old Apr 3, 2007 | 01:47 PM
tastyZL1's Avatar
seeing as how im doing a cam swap, how much is it to recharge my ac system?
Old Apr 3, 2007 | 02:51 PM
OBE1 95Z28's Avatar
I got mine recharged for $83 a couple of years ago. That assumes that none of the other parts went bad from the system being open to humidity for any length of time.
Old Apr 3, 2007 | 04:45 PM
blown383's Avatar
Crap... my stuff has been sitting in the garage open to the elements for 2 years now. I wonder what needs to be replaced and how would they check for it?
-B
Old Apr 3, 2007 | 05:19 PM
tastyZL1's Avatar
mine will only be open for a day so yah
Old Apr 3, 2007 | 08:46 PM
johnnyb's Avatar
with no refrigerant in the a/c system, would the ses light come on?
Old Apr 3, 2007 | 09:19 PM
Dave89IROC's Avatar
a code will set, but the light won't come on
Old Apr 3, 2007 | 09:20 PM
Dave89IROC's Avatar
-B
replace the accumulator(don't install until you are going to get it charged), everything else should be ok, make sure the system is vacuumed down for at least 30 minutes
Old Apr 3, 2007 | 10:43 PM
jeepbeast's Avatar
i drained my air about 4 months ago when doing my head/cam swap. should i be alright if i just go to a shop to have it filled? or does damage come that quickly from being empty?
Old Apr 4, 2007 | 02:22 PM
White96Z28's Avatar
Why are you dumping the AC to do a cam swap? take the condesner and use a bungee strap to hold it up out of the way but don't unplug any lines... You should have just enough room to slide the cam in that way.
Old Apr 4, 2007 | 02:59 PM
jeepbeast's Avatar
i know now. it's my first head/cam swap and i read somewhere to disconnect the air lines and condensor attached to the radiator. just learning as i go along. with being disconnected not too long, does damage happen that fast?
Old Apr 19, 2007 | 06:46 PM
Ellis's Avatar
If you open up the system (even for just a short time), the correct procedure is to draw down a vacuum before recharging. If it sits open for a while, you may want to get a new accumulator with a fresh dessicant.
Injuneer
Apr 25, 2022 06:22 PM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
RUNMYTA
Jul 15, 2015 07:50 PM
