where can i get endlinks?
Old Apr 3, 2007 | 10:22 AM
nodnarb481's Avatar
Stock ones or aftermarket that fit the stock bar. I need the endlinks for my front sway bar because i destroyed the old ones taking the bar off..
I <3 my breaker bar
Old Apr 3, 2007 | 10:54 AM
2000GTP's Avatar
Spohn sells them on their site. I'm sure you can find them at Summit or Jegs as well.
Old Apr 3, 2007 | 02:47 PM
OBE1 95Z28's Avatar
Pretty common item at most Auto Part stores. Take an old one with your to match the size and now's your chance to throw in some poly bushings.
Old Apr 3, 2007 | 11:44 PM
Many auto part stores stock the ES end links with poly bushings.
Old Apr 4, 2007 | 02:50 AM
revtime's Avatar
Autozone and Advance have them on the shelf here in KC.
Old Apr 8, 2007 | 08:56 PM
Severous01's Avatar
yeah...autozone.
cut them down to factory length. or, if you're lowered, set up the rear and measure from sway bar level with ground to the lower mount on the axle/arm. cut to measured length...sway bar should be level with ground when on level ground and even weight dist.
96SilverRam
Nov 20, 2016 11:19 AM
96SilverRam
May 5, 2015 09:56 PM
BLK1997Z28
May 1, 2015 12:23 PM
Phillips
Jan 15, 2004 01:59 PM
Steve in Seattle
9
Jun 5, 2003 04:57 PM
