clutch work...some basic questions
Old Apr 1, 2007 | 08:40 PM
teke184's Avatar
this is on an LS1 car
if i have my flywheel resurfaced...do i have to install a shim? or can the difference be taken up with an adjustable mastercylinder?
how much is a GM replacement throwout bearing? i see a centerforce unit online for $80...sounds like ALOT.
is a SPEC 3 clutch disc compatible with the SPEC 4 pressure plate. my 4 disc is worn out, and i can only find the 3 online (not to mention i think i'll get more life out of it).
thanks
Old Apr 1, 2007 | 09:26 PM
96ZCamaro's Avatar
As far as shimming it out I do not think you will have to do that, or make any ajustments really. I had mine resurfaced and I did not do anything to ajust it and it is just fine. But as for your other questions I have no clue.
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
