90mm Throttle Body N2O Plate
Old Mar 30, 2007 | 10:37 PM
Boosted_Z28's Avatar
Is anyone making a nitrous plate for a 90mm "Ford" style throttle Body? This is something that I am using on an LT-1 with a single plane intake.
Old Mar 31, 2007 | 12:08 AM
Ray@NitroDaves's Avatar
can you send me some pictures and I will see what I can come up with.
also what intake manifold are you using?
Old Mar 31, 2007 | 10:27 AM
I'm still waiting on the parts...throttle body and 90* intake elbow, so I'll get some pictures taken when they arrive. I am looking for a nitrous plate that will fit between the T/B & 90*. I'm using an Accufab 90mm Ford style throttle body. The intake is a Edelbrock Victor EFI. (I prefer a plate similar to the LT-1 58mm one that I currently have on order from Nitro Dave's)
Old Mar 31, 2007 | 05:03 PM
if you are using the victor...you can use any of the carb' plates...the choice will depend on the jetting option and single or dual stage. they will mount in between the elbow and the intake.
Another option if you are fighting clearence is to install a spraybar into the intake
Old Mar 31, 2007 | 10:12 PM
I've considered using the standard 4150 Holley style plate, but this increases the height of the 90* elbow and makes for an even tighter cowl/hood clearence issue. I've had to have a custom made elbow to give me the clearence necessary. The reason I am looking for a 90mm plate is because I think it makes for a lot cleaner looking install.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
