What subframe connectors
Old Mar 29, 2007 | 01:33 PM
CamaroSS8887's Avatar
Do the ones that dont connect in the middle still work well?... and does anyone reccomend a certain company?
Old Mar 29, 2007 | 01:34 PM
and boxed or tubular?
Old Mar 29, 2007 | 01:42 PM
Eric@Victory Racing's Avatar
UMI and Spohn both make a nice product. I am not partial to boxed or tublular, but they have to be weld in.
Old Mar 29, 2007 | 02:01 PM
danhr's Avatar
tubular is the way to go
the 3 point (connect in the middle) are stronger, but the 2 point works just as well.
I went with umi's tubular 3 point sfc's (umi is the only company that makes tubular sfcs btw), because they highly recommended them over the two point when running a tunnel braced torque arm.
Old Mar 29, 2007 | 02:41 PM
2000GTP's Avatar
I have the Spohn two-point, tubular, weld-in style connectors. They tuck up nicely and made a huge difference.
Old Mar 29, 2007 | 06:03 PM
FASTFATBOY's Avatar
Global West.
Old Mar 29, 2007 | 06:10 PM
mdacton's Avatar
I got mine from mac.....in 99 they probly went out of bis now
they are made from 1 3/4" stock and 1/8" plate...tubular and weld in
Old Mar 29, 2007 | 09:21 PM
Greed4Speed's Avatar
Global West makes some big tubular ones. If I had known about them waaay back when I did mine, I'd have gone that route.
Old Apr 7, 2007 | 02:42 AM
Z-RATED94's Avatar
KBDD, nuff said!! .................................................. ..........J/K That was my pick and I love em, but to each his own.
Old Apr 7, 2007 | 08:45 PM
eagleknight97's Avatar
Whats the loss of ground clearance like with those? They say they are the tightest fitting of the 3pts out there, but want to get a owners perspective.
Old Apr 7, 2007 | 10:03 PM
Bayer-Z28's Avatar
The SLP DD's are a stout piece. (surprising..I'm recommending SLP stuff.. ..)
My buddy has them and his car will not twist AT ALL! he can jack the car up from the center and he allways has one rear wheel off the ground entering/exiting his DW.
Old Apr 7, 2007 | 11:56 PM
Bayer, ya got SFC's spelled SCF's in your sig, just noticed that.
Also, what kind of SFC's do you have and hows the ground clearance with the SLP's?
Old Apr 8, 2007 | 12:03 AM
danhr's Avatar
clearance is great! they tucked very well.... looking at it from the side, the only thing you can see is the part a part of the bracket that connects to the lca's. I'm sure I could get rid of that if I ever got around to welding mine in (mine are just bolted in at the moment... I really need to redo them). Driving around, I can't give an honest opinion because when I put my SFC's on I also put on a tunnel braced torque arm that sits extra low for long tubes, which did kill my ground clearance a good bit.
Old Apr 9, 2007 | 09:51 PM
krazykorean35's Avatar
global west tubulars. welding shop told me they were the best fitting set of sfcs theyd ever welded in...and u dont lose any ground clearance with tubular
Old Apr 9, 2007 | 11:02 PM
jer4251's Avatar
love my SLP double D's
