Cooling problem
Old Mar 29, 2007 | 11:53 AM
crucescamaro's Avatar
Cooling problem
I have a 95 camaro w/a 3.4L V6. I noticed the coolant level in the radiator was low so I filled it. After driving it to work and back, coolant was leaking from the from somwhere in the front of the engine (I think its the water pump). As the coolant level dropped in the radiator, the leak stopped. Car runs great, temperature never goes above 190. I am wondering if the radiator cap is bad and not letting the coolant overflow into the overflow reservior. If not allowed to overflow, would the expanding coolant leak out of the water pump until the pressure equalizes? Any help on this issue would be appreciated. I really don't want to have to tear out the water pump
Old Mar 29, 2007 | 12:07 PM
Z28SORR's Avatar
Doesn't really work this way, but rad. caps are cheap. So buy anew one and then fill your rad. back up and get everything nice and hot, and find out where the leak is!!!
Old Mar 29, 2007 | 01:18 PM
PentaVolvo's Avatar
try and located where it is coming from... that said my water pump on my 3.4 L went out at around 90k or so i swapped it out in an afternoon. My buddys went at around the same mileage as well
Old Mar 29, 2007 | 02:25 PM
2000GTP's Avatar
I'd pinpoint the leak, whether it be the water pump, a hose, or the radiator itself.
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
