4l60e lock-up comes and goes,
Old Mar 28, 2007 | 05:14 PM
kline454's Avatar
my 4l60e in my 1995 camaro was just rebuilt and it wont lock-up in 4th 9 out of 10 times but when it works, it works great, there are no codes and no other problems, any ideas??
Old Mar 28, 2007 | 08:41 PM
12SCNDZ's Avatar
What converter is in it? A non lock-up/floating issue can be caused by several dofferent reasons. One is the converter, itself. We've seen cheaper converters do this from initial install. The lock-up solenoid, tcc regulator valve, or computer inputs could be other causes.
You might want to run the car with a scanner to check your data information. Make sure the computer isn't commanding it to come out of lock-up. The input shadft in the transmission can wear where the lock-up o-ring rides, also.
Shouldn't your transmission builxder be addressing this issue?
Frank
CPT
Old Mar 29, 2007 | 09:57 AM
kline454's Avatar
I put the trans together and its a tci stall that was in the car before with no problems. i replaced the prm tcc senlonid because of a no 1-4 gears, now im thinking its the tcc senlonid but im going to get at it with the tech2 sometime today.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
