Car runs like crap with open headers
Old Mar 27, 2007 | 08:38 PM
phoenix1987's Avatar
I have a 87 Trans Am with a Ls1/t56. It has all of the bolt ons with a TR230/224 cam. I do not have a tune. Here is my problem. The car is running like crap. It seems to run good until the car warms up, then it idles lower and backfires (sometimes very badly) and sometimes dies. I am not throwing any codes.
I have the EGR, AIR, Evap, Rear O2s, and all of that fun stuff tuned out. Could this be becuase of the open headers? I am using the LS1/Third Gen headers from Hawks Third Gen with no piping added on, just straight headers.
I also took the car around the block. Seemed to not have the power it should and ran worse as the car heated up.
The car runs and idles good if the engine is cold.
I am going to have the car towed to the shop for the exhaust install. I hope that helps.
Old Mar 27, 2007 | 10:09 PM
ReNxWar's Avatar
A tune would probably help you alot, since you have headers and a cam. I would start there and work your way back. Also check for vacuum leaks from removing the EGR/AIR/EVAP/etc. Scan all the electronics to make sure they're working right and they didn't get knocked around with the engine swap. Are you sure everythings wired up right?
Old Mar 27, 2007 | 10:37 PM
SSpdDmon's Avatar
Fresh air is hitting your O2 sensors throwing off fueling. Get the exhaust put on and you may have to replace the O2 sensors. The reason it works well cold is because the O2's are ignored until the coolant temps reach a certain threshold.
Old Mar 28, 2007 | 08:54 AM
AL SS590 M6's Avatar
Moderator
Right on the money here.
The first couple of minutes after a cold start up the PCM operates in open loop mode using tables to run the motor.
Then it switches to closed loop where it looks at the O2 sensors for input.
And with the open headers the O2s are being exposed to air that isn't going thru the motor and the PCM tries to tune for this air which throws it way out of wack.
Old Mar 29, 2007 | 08:00 AM
RE AND CHERYL's Avatar
Not having a tune for that cam certianly will have something to do with it. Having open headers will let the O2 sensors get exposed to oxygen, make the ECM think it's lean, and it will dunp fuel like crazy.
Just courious, wherre do you live???
Re'
Old Mar 29, 2007 | 11:52 AM
I live in MN. I have an appointmaent set up for my exhaust work!
Old Mar 29, 2007 | 12:09 PM
Ultra_Dog's Avatar
Read up on engine exhaust back-pressure. You need it to run right.
Old Mar 29, 2007 | 06:29 PM
SSpdDmon's Avatar
Uh...no you don't.
Old Mar 29, 2007 | 10:29 PM
Cool. I bought parts from a guy in Maryland who was installing a LS1/T56 combo in a 87 TA with LT headers. Kinda wierd.
Re'
Old Mar 31, 2007 | 05:09 PM
SSpdDmon's Avatar
Originally Posted by SSlither
Man you know your ****! It took me awile to think of that, and I spoke with two mechanics (15+ exp for both) at my full service shop (Lambs) and they completely agreed!
Dam straight!
Yeah, you dig around in the LS1 PCM long enough and you'd be surprised what you never knew.
Old Apr 3, 2007 | 11:58 AM
1st and goal's Avatar
Check your grounds.....
I did a swap into a 73 Z/28 and when we first got the car running on open headers it ran fine until it got warm and it ended up being a bad ground.
Good luck
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
ro2207
Dec 4, 2014 06:18 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
