A4-M6 swap - running problem - computer??
Old Mar 27, 2007 | 11:07 AM
CrazyLT1's Avatar
Hey guys,
I just did the A4 to M6 swap - and everything for the most part is running fine. I have NOT flashed the computer over to the M6 program yet.
My only problem is that when pushing in the clutch and slowing down - the motor wants to die out. I sometimes even have to put the car in nuetral and keep pushing the throttle down while stopping in order to keep it from stalling out. Other than that - the car idles fine, runs fine, accelerates fine, and cruises fine.
Does this problem have something to do with the fact that I have not re-flashed the computer over to a M6 program yet?? My car is a 1997 camaro with the LT1. I was told by someone that once the computer is re-flased, then this stalling problem while pushing the clutch in and slowing down will go away - is this true??
Old Mar 27, 2007 | 11:52 AM
VinceTrifecta's Avatar
It depends on what is causing this problem.
But I could see how this could cause a problem - the PCM has inputs that tell it which gear the automatic transmission is in, and it adjusts idle strategy based on those inputs (e.g. if it is in DRIVE or PARK/NEUTRAL). Since those inputs likely aren't hooked up, or reporting the correct information anymore, it may be choosing the wrong idle strategy.
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Absolute Z28
Jul 19, 2002 02:21 PM
