Ram adj clutch master cylinder
Old Mar 27, 2007 | 09:41 AM
teke184's Avatar
looking into buying an adj MC.
the McCleod is $325....and i know it's a good unit.
but i see TR sells a RAM unit that is adjustable, but is only $160
the car is not a major race car, but it does have the SPEC 4 clutch and fidanza flywheel.
just wondering what the difference is that warrents the price difference.
Old Apr 11, 2007 | 08:57 PM
teke184's Avatar
got it...and installed it today...
it's a stock GM unit with the adjustable heim joint attached to the shaft
comes with a pin for the hyd line, and the small 0-ring
now on mine i had to do some annoying surgery...the little ball socket on the heim joint was too wide to allow the retaining clip for the clutch pedal to slide on.
so i had to delicately touch it up with a hand held grinder...since its hardened steel...which isn't easy on a piece of metal that is the diameter of a nickel.
the thickness of the joint on the stocker was 13.25mm....the RAM unit was 13.75mm
i shaved it down to 13 to be cautious.
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
timmy39120
May 2, 2015 05:12 PM
Ringmaster72
Mar 19, 2015 03:32 PM
