little question
Old Mar 21, 2007 | 05:06 PM
streetracerx's Avatar
little question
so it was around 40 degrees out and i had been gentle with my car the whole way. I went to mcdonalds and sat in the drive thru for maybe 5 minutes and in that time the engine heated up enough to turn the fans on at 220 degrees..is this normal, i mean it usually always does in the summer in the drive thru, but when its only 40 degrees out?
Old Mar 21, 2007 | 05:16 PM
2000GTP's Avatar
Doesn't sound like an issue, as long as it didn't peg in the red and the cooling fans kicked on, it sounds normal.
Old Mar 21, 2007 | 05:23 PM
ya, i have a 160 tstat i will be putting in in the next week or so, will that help keep the temp down a little so the fans dont come on as often?
Old Mar 21, 2007 | 05:28 PM
2000GTP's Avatar
It will probably have little effect until you get your PCM tuned to adjust the fan on/off speeds. Then your car will be running alot cooler.
Old Mar 21, 2007 | 05:34 PM
haha it just so happens i just ordered a tune from the new tuner guys at trifecta performance to have the fans come on sooner. nice
Old Mar 21, 2007 | 06:16 PM
2000slp2768's Avatar
doesnt sound like a problem. If it happened well you were driving I might be worried. but when you are stationary you dont have any air flow thorugh the radiator so the fans will come on, even at that low of an outside temp.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
