Rollmaster timing chain
Old Mar 6, 2007 | 02:31 PM
mook99TA's Avatar
I am looking at the rollmater adjustable double roller timing chain but it says when used with an asp crank pulley modifications are required to be done to the pulley has anyone used these timing chains. Here is the link for the timing chain
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
its about half way down the page.
Old Mar 6, 2007 | 02:37 PM
iamsickofitall's Avatar
the double roller will need to use spacers to clear the oil pump - they come with the kit. if you have an older style ASP pulley, you will need to have it machined to seat properly on the crank snout.
Old Mar 6, 2007 | 03:18 PM
mook99TA's Avatar
I don't have the asp pulley yet but that is the one I want. So with the new ASP pulley you don't need to machine it?
Old Mar 6, 2007 | 03:33 PM
i don't think you would have any issues, but you should call who you are ordering from or ASP to double check.
this is a picture of the machining that is/was required
as long as you're not going to be making insane power and/or spinning your car over 6500rpms all the time, you'd be a good candidate for an LS2 timing chain. that's what i'm running in my car making 420rwhp. I rarely take it up to it, but my rev limiter is set at 6800rpms.
Old Mar 6, 2007 | 05:58 PM
mook99TA's Avatar
how much does that cost and where did you have it done?
Old Mar 6, 2007 | 06:09 PM
mook99TA's Avatar
so I should just go with the SLP timing chain and the SLP pulley?
Old Mar 6, 2007 | 06:38 PM
Greed4Speed's Avatar
Just get an LS2 timing chain for $35.
Old Mar 6, 2007 | 06:51 PM
LBJ's Avatar
LBJ
+1.....just swap the chain.
Old Mar 6, 2007 | 07:25 PM
mook99TA's Avatar
whats the difference between the LS1 and the LS2? And isn't it easier for timing with the adjustable if I want advance or retard the timing
Old Mar 6, 2007 | 07:57 PM
LBJ's Avatar
LBJ
LS2 is a thicker/stronger chain than the LS1 but it fits on the LS1 sprockets just fine. More than likely who ever you get your cam from will have the advance ground into the cam so you just install it straight up.
Old Mar 7, 2007 | 01:49 PM
What LBj said. Its the same chain used in the LS7 so I would think it would be more than sufficient for a built LS1.
Old Apr 16, 2007 | 08:49 PM
mook99TA's Avatar
where can I get the LS2 chain?
Old Apr 16, 2007 | 09:04 PM
I got mine from Texas Speed, but I think the WS6store and some other sponsors have it also.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
