Were is the NOOB section!? looking for some input
Old Mar 4, 2007 | 06:42 PM
Tricked-Out-Toy's Avatar
Ok heres the deal last night i was out playing with a buddy who has a nice head and cam ls1 and he walked me hard every time. so I need more power and turboing has been something ive wanted to do for a LONG time.
heres my setup.
lt1 LE3 heads LE2 cam 1.6 pro mag, morels, ported intake, 58mm tb, 30# injectors, headman long tubes, 3" duals.
MY goal- Stock bottom end pushing 550 rwhp
Now my question
1. The LE3 heads 2.02/1.60 have a few areas in the runners that burned through the walls when they ported them and were sealed up with silicone. do I need to get rid of these heads? if so is it worth goin with a ported head or just use stock to meet my goals?
2. since im staying with a stock or stock ported heads my compresion ratio is going to be on the higher side even with the deepest dish pistons. so what I need to know is with the stock displacement what pistons should I look for and what would be my max safe boost levels with pump (93) gas. oh and YES I will be air to air intercooling.
2a. would punching the block out to .30 or .60 make a big enough difference in compression ratio to make it worth while?
3. since this isnt going to be a max effort build would you recommend using a turbo from a production car/truck or buying a t3/t4 from a manufacturer? also what size would I be looking for?
4. Im pretty sure 500-550 is starting to get to the upper limits of the 2 bolt block but ill have to live with that. my question is will the stock PM rods be ok?
Ok I think thats all I need to know the rest im "searching" for. thanks
Old Mar 4, 2007 | 08:14 PM
slowZ's Avatar
umm maybee some one else can chime in here, but i think standard practice is to weld the hole shut and report them and not using silicone???????
Old Mar 5, 2007 | 08:04 PM
roguedriver's Avatar
I read your web page. So your car ran a 13.4 with a 2.58 60ft? Then you put the heads, cam and exhaust on? My suggestion would be to slap a set of Mickey Thompson drag radials on there before dumping a butt load of cash into a turbo setup and run that dude again. You thought you were spinning tires before! Slap a turbo on that thing and you'll be watching him pull you ever worse while your sitting there going up in smoke. Don't think you'll go from a roll either. 2nd and 3rd will go up in smoke also with a turbo without the right tire. If your still going that route though, you should be able to get a stock ported LT1 head with the right piston down to 9:1cr which should be ok if your air to air. No reason why you couldn't put a water/methanol kit on there to help things out also. 8 to 12psi should be fine.
Ken R.
Old Mar 5, 2007 | 09:22 PM
Wow forgot about those times lol ya those were a couple years ago. my 60's are still suffering with the street tires but my best so far has been 12.8 @ 112 with 2.02 and 2.1 60,s. I have a set of MT street ET's ill be using this weekend to get my times down plus I found out that I was running out of fuel up top. so with the new pump and stickies I should be lower 12's. and that race with my buddy was from a 40mph roll both time. So ya Im working on the traction issues
Now back to question 2. how much of a difference would you see with ported LE's Vs stock. Or how about just putting bigger valves in stock unported head? thanks for the help!
EDIT: Lloyd cleared up the silicone issue. its been a while since I installed the heads and couldnt remember exactly were I saw the silicone. But its in the intake runners from the porting below the rocker arm stud. the silicone was used on the studs to seal the runner.
Nayr
Mar 3, 2023 08:34 PM
Ericksd
Jan 20, 2016 06:07 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
