Pressure plate bolts and flywheel bolts p/n please
Old Feb 28, 2007 | 08:13 AM
always faster's Avatar
Smile Pressure plate bolts and flywheel bolts p/n please
Just like the title says,im changing my cltutch and i need the oem part number for the following parts:
-Pressure plate bolts
-Flywheel bolts
Thank you
Old Feb 28, 2007 | 08:35 AM
Javier97Z28's Avatar
Moderator
Flywheel bolts:
Qty: 6 7/16-20 x 31/32 Part# 12337973 GM List: $2.34 each
Pressure plate bolts:
Qty: 6 3/8-16 x 1.62 Part# 10079898 GM List: $3.25 each
Old Feb 28, 2007 | 09:08 AM
Originally Posted by Javier97Z28
Flywheel bolts:
Man that was quick, thank you.
-Does the pressure plate bolts fit with any standard pressure plate(im using a ram hdx kit with a stock resurfaced flywheel) forgot to ask in the first post
Thanks again
Old Feb 28, 2007 | 09:37 AM
OBE1 95Z28's Avatar
Thanks again
The stock bolts will fit fine.
Old Feb 28, 2007 | 09:39 AM
Woohoo im all set
Thank you
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
HectorM52
Jan 30, 2015 11:08 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
