headlight wont go down help please
Old Feb 24, 2007 | 12:02 PM
tastyZL1's Avatar
ok so i got into my car turned on my headlights they both worked fine 10 mins later i turned my sub up and then the passenger side one burnt out and will only go down half way?
is it the motor, light, or fuse, or something else?
thanks for the help guys
Old Feb 24, 2007 | 12:05 PM
Brent94Z's Avatar
Super Moderator
The left light burnt out or the sub fried?
The light and the headlight motor are independent of each other.
Is your battery good? Sub might have drained the battery.
When you turn the lights back on does the light go all the way back up and then still goes only half way down when you turn the lights off?
Old Feb 24, 2007 | 12:16 PM
tastyZL1's Avatar
they light is out and there is a new battery in the car
when i turn the lights on the light will go all the way up without problem but when i turn it off it will only go half way down
Old Feb 25, 2007 | 06:56 PM
tastyZL1's Avatar
anyone?
Old Feb 25, 2007 | 07:44 PM
smithtim's Avatar
since it will raise the light up kind of elimatents the fact that the motor is fully broken but it may be just wearing out ( I know there is a frequent problem with the plasitc gear inside the headlight motor but usually you can hear it grining)... have you tried lowering the headlight manually as it may just be that something is stuck down in there that is prventing the thing going down fully
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
