Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
High compression, should I get an ignition box?
Old Feb 23, 2007 | 12:38 PM
jsetzer's Avatar
I am running @ 13.0 and have been chasing some high end miss problems.
Been through optis, coils, icms, wires, plugs.
Running # .040 gap on ngks tr6 plugs.
I'm thinking at this point it wouldn't hurt, and I need a timing retard before I spray bigger.
So msd digital 6?
Old Feb 23, 2007 | 03:17 PM
2000GTP's Avatar
I think you would see some benefit of running an ignition box and having a hotter spark. Have you considered the Mallory 685 box at all? It has a timing retard and window switch as its built-in features.
Old Feb 23, 2007 | 03:33 PM
seawolf06's Avatar
I got the 685, but haven't installed it yet.
Old Feb 23, 2007 | 07:53 PM
jsetzer's Avatar
I have a window switch in my progressive controller.
Old Feb 25, 2007 | 08:16 PM
rskrause's Avatar
Moderator
Yes, with high cylinder pressure a stronger spark is often needed. Can't say for sure your combo will see any benefit though. As far as brand, I have no big preference.
Rich
Old Feb 26, 2007 | 11:16 AM
jsetzer's Avatar
Thanks everyone, if nothing else it will be worth the piece of mind to have the soft limiter and the timing retard.
On the same topic, has anyone used the opti sensor to drive the injectors and a crank trigger to drive an ignition box?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
