Whats' wrong with my sub??!
Old Nov 21, 2002 | 07:42 PM
Omega9's Avatar
Exclamation Whats' wrong with my sub??!
Whenever i turn up the volume to the usual level, I can hear my sub vibrate as if I placed something in front of the cone and let it vibrate against it. What could the problem be? Is my sub permanently f**ked? (10" L7 kicker solo baric dual 4 ohm) (older version) If it is screwed, should I sue Trick Daddy?
Old Nov 21, 2002 | 09:20 PM
onoiocoko's Avatar
i dont know what im talkin about but that sounds like its blown. check around the rupper edge seem for like a crack or rip. i dont know. but sometimes u can get them fixed if its not a big rip good luck. just something to try but i dont know much about it.
Old Nov 21, 2002 | 09:31 PM
LS1 RULZ's Avatar
Look inside the enclosure and make sure nothing is touching the cone.
Old Nov 21, 2002 | 10:19 PM
Omega9's Avatar
Nope. Nothing touching the cone, and no rips. It only vibrates when I turn it up to 18. When its on 16-17 its fine.
Old Nov 22, 2002 | 12:24 AM
LS1 RULZ's Avatar
Sounds like you may have a partially detached voice coil then. Time for a new one.
Old Nov 22, 2002 | 06:50 AM
rthompson's Avatar
or the spider glue around the basket let loose, or partially loose.
Old Nov 22, 2002 | 11:08 AM
Omega9's Avatar
Could this be due to playing the sub when its not warmed up enough? In cold weather I wait about 10-20 minutes after the interior is warmed up before I turn the bass up. Should I have waited longer? If one of the voice coils is detached, is it a fairly easy fix?
Old Nov 22, 2002 | 11:37 AM
LS1 RULZ's Avatar
The cold shouldn't matter. Car audio speakers should already take temperature extremes into account when they are designed and manufactured.
If the VC is detached you'll either have to scrap it or send it to the factory for repair. It's not a fix that can easily be done at home.
Old Nov 22, 2002 | 01:22 PM
x7x7's Avatar
I would check the spider first, you may be able to fix that.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
