4.25" P1SC pulley #
That pulley did make 8 psi at 5700 rpm on the stock motor that it was on. I'm 100% positive with that. What type of air inlet do you have on there? With revving it to 6000, and with no filter on it (maybe?), I could see it making 10 psi easily.
Yeah, I know. I know it's probably extremely cold up there where you're at (it is here!), so once it gets warmer this spring, that boost level will come down a bit. It's not uncommon to see a pound or 2 more boost in weather conditions like this, because of the colder, dense air.
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
.. if it keeps happening the motor is going to blow alot sooner then i want.
