What offset and tire size whould i need
Old Feb 3, 2007 | 09:53 AM
lineybiker_11's Avatar
i have a 99 z28 and i'm looking at some C6R rims off ebay the rears are 20X10 and the fronts are 19X9.5 and like the title says what tire size and offset would i need for these.
Old Feb 4, 2007 | 10:52 AM
The offsets should be within the guidelines mentioned in the FAQ (see the second page). Since the tire for a 20" wheel is most likely going to end up being a larger diameter than stock, you want an offset that will put the 20x10" wheel pretty much "centered" in the wheel opening, probably about 54-56mm. Any less offset, and its going to be close to the fender lip. Any more offset and its going to put the tire close to the inner fender liner. A typical size would be a 275/30-20 (26.5" diameter) or a 285/30-20 (26.7"), both larger than the stock 25.7" tires.
For the fronts, you need to work in the range of 45-55mm. The tire sizes for a range of 19's is shown in the FAQ.
Old Feb 5, 2007 | 08:07 AM
thanks!!
HectorM52
Jul 30, 2017 11:46 AM
LD Kirk
Apr 30, 2015 08:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
blac94Z
Mar 6, 2015 07:55 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
