What needs to be forged?
Old Jan 31, 2007 | 09:24 AM
jasycZ28's Avatar
I am about to throw a LT1 in my 73 Z28. When I rebuild it I am going to stroke it to 383. Just wonding what all NEEDS to be forged to spray as safe as possible. I am kindna on a budget but I will spend the money for the right parts. I am going to build the motor for a N/A setup but would like to put a 100-200 shot on if I want to later on. I know the pistons need to be forged. Most stroker kits come with forged pistons and rods but the crank is cast steel/ nodular iron. Could I use this stoker kit with nitrous? Give me your ideas and wisdom.
Thanks,
Joshua
Old Jan 31, 2007 | 12:04 PM
Ray@NitroDaves's Avatar
the internal components need to be dictated by your goals for the vehicle.
What do you have in mind for the car?...I.E. I wanna run 8's etc
How much power do you plan to make, how much nitrous?
IMO...it is not that much more to buy a forged crank over a cast since you are buying a new one anyway.
Old Jan 31, 2007 | 12:26 PM
jasycZ28's Avatar
I don't care how much power I have my goal is ET. My goal is 10.99999 or lower. Driving a 10 sec all motor car won't work on the street for the most part. So I was thinking have a engine that can run mid to high 11's. 383 stroker good heads and cam. Then add the nitrous later down the road to hit the 10 sec mark. I still would like to be able to daily drive or go on a long trip it if I wanted to.
Old Jan 31, 2007 | 12:54 PM
Bandit 1's Avatar
I bet you can get away with just forged pistons, maybe throw some rods in for insurance
Old Feb 2, 2007 | 02:18 PM
slo_z28's Avatar
I put 20+ 15 lbs. bottles through a stock 130K lt1 (hypertechtic), always spraying from 150-200 shot (wet NX). The only reason I quit is because I built a stroker motor for the Fleetwood ( yes fleetwood, lol)
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Cbr02
Aug 24, 2015 07:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
