need help!! Rear ABS Wheel Wont Come Off
Old Jan 28, 2007 | 11:22 AM
diamondhill's Avatar
Unhappy need help!! Rear ABS Wheel Wont Come Off
i was getting ready to put my new ws6 wheels on,when i tried to remove my rear wheels and they wont come off , i ve only had this car for about a year so i never had to remove the back wheels. i think the wheels came off of like a 97 or newer and were forced on by the previous owner..any ideas on how to get the wheel removed ???
Old Jan 28, 2007 | 11:38 AM
Common problem, if the previous owner didn't take the time to enlarge the hub hole in the rear of the 97+ wheels.
Try getting some leverage behind the tire, using a prybar against the subframe or some "solid" part of the wheel well (jounce bumper bracket????). Pry against the tire, rotate the wheel 1/8th turn, pry again, and keep doing this until they start to come loose.
You're lucky the interference fit did not crack the wheel center.
Old Jan 28, 2007 | 12:05 PM
Thank You very much Ijuneer, for the advice and responding so quick!
Old Jan 28, 2007 | 05:32 PM
still no luck they wont budge! im trying not to damage the rims beause some one wants to buy them, but i might not have a choice but to beat the crap out of them
Old Feb 23, 2007 | 07:52 PM
LT1_383's Avatar
You can hit the inner lip of the rim with a good sized sledge and really not cause any damage. I've done it to steelies even and haven't caused any damage. Those were rusted on rims so it might be a little different but should work just the same.
Old Feb 23, 2007 | 08:19 PM
jer4251's Avatar
sit on your *** and just kick the tire with both feet.
or just slowly wiggle the wheel back and forth
carguy0119
Apr 11, 2016 11:11 PM
jj_burchiel
Mar 21, 2015 12:51 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Dimoncutr
Aug 18, 2002 09:39 PM
