ls7 into lt1 car
Old Jan 28, 2007 | 08:22 AM
camarolt4ss's Avatar
ls7 into lt1 car
hey guys i have a line on a 2006 c6 z06 complete engine and trans, harness and ecu......
now what might be needed to do this swap into my 97ss.....
any and all info would be great
thnx
Old Jan 28, 2007 | 09:23 AM
Need4Camaro's Avatar
thnx
I'm not too inclined on these situations however I believe for the price of the engine / trans / harness / ecu / misc stuff to properly perform the conversion ... You'd be spending the same just to go ahead and buy a new Z06...
Old Jan 28, 2007 | 10:27 AM
actually the engine the trans and the harness and the ecu i have for 2000, so thats not an issue.....
all i need to know is what else am i needing....
Old Jan 28, 2007 | 11:31 AM
2000GTP's Avatar
GM High Tech Performance did the swap in a 99 Camaro a while back, http://www.gmhightechperformance.com...et_camaro_z28/ Here is an idea of what they needed to do the swap and the end result.
Old Jan 28, 2007 | 11:39 AM
oh thats just so dirty it makes me smile lol
Old Jan 28, 2007 | 12:04 PM
seawolf06's Avatar
Prolly make it much easier to sell your LT1 and buy a LS1 since you would have to do everything that would normally be done for LS1 conversion.
Old Jan 28, 2007 | 12:15 PM
my car means alot to me, so its not going anywhere..... id rather suffer with extra work, cause the sentiment is worth more then money to me
Old Jan 28, 2007 | 12:51 PM
Geezer powered's Avatar
I don't know about this one but If you want it and have the means to do it go for it. If it was me I'd just build one hell of a lt1 with a turbo setup.
Old Jan 28, 2007 | 12:53 PM
i have a 800ish hp lt1 turbo right now
this is just something i wanted to do as a project with a car that my father and i started to build
Old Jan 28, 2007 | 06:49 PM
seawolf06's Avatar
Definitely need the LS1 K-member. I guess that's where you start and go from there. Seemed like the magazine guys did it easily.
Old Jan 28, 2007 | 09:45 PM
Capn Pete's Avatar
You know the trans-axle won't work in the F-body, right? Unless you have AMAZING fabrication skills?! But an LSx into an LT1 F-body ... that's been done before ... you should have no/few problems doing that .
Old Jan 28, 2007 | 09:47 PM
Blue89Bird's Avatar
i dunno, I don't see ANYONE getting rid of an LS7 for 2k. Even LS1's go for more then that, so even if the junk yard or whatever was mistaken, it would still be more then 2k
Old Jan 28, 2007 | 10:05 PM
Ah, I understand... Sorry then... In that case keep me informed because I want to see how it comes out...
Old Jan 28, 2007 | 10:21 PM
your right it should cost more then that.... alho when u have friends with $$$$$, he is going with the c5r block and build up so........
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
Bearmans
Dec 3, 2014 05:28 AM
USAirman93
Nov 24, 2014 03:37 PM
