clutch install?
Old Jan 23, 2007 | 11:29 AM
str8-6's Avatar
clutch install?
does anyone have a website to the steps of installing a clutch in a 94 camaro with t-56. im getting a new clutch this week and it would be nice to have a list or procedure to print out and follow to make sure everything goes smoothly and i dont forget anything. (adhd!)
thanks,
mike.
Old Jan 23, 2007 | 11:41 AM
95LT1conv's Avatar
http://www.zmydust.com/lt1clutch.html
ask and you shall receive.
Old Jan 23, 2007 | 01:27 PM
Javier97Z28's Avatar
Moderator
Heh, I just read over my own install guide and realized one thing could change (made that guide years ago):
Just remove the torque arm from the trans, you shouldn't have to take it out completely.
Old Jan 24, 2007 | 12:31 PM
str8-6's Avatar
nice write up. you did good. when i install my clutch ill definitely be using this. and by the way number 17 might be repeated a few times while doing this install. lol. but ill let you all know how it goes as and when i do it.
thanks,
mike.
Old Jan 25, 2007 | 11:49 AM
mzgp5x's Avatar
I've done it 3 times. (97 - SS MM6). One thing I do is...
When engagement of the main shaft to the pilot bearing, you must align three (3) pieces. (Hseing dowels/ Main shaft clutch spline/ and, main shaft pilot bearing). Since those plastic alignment tools have a wide tollerance, alignment may be difficult. I assemble the clutch fork into the throw bearing, push the clutch in slowly by hand (not full stroke). This releases the clutch pressure plate in alignment with the dowel and pilot bearing centers, and, moves the trans forward into engagement. Works every time for LT1 due to design of the clutch mechanism. It took me 2 hours to figure this out, but not found in any manuals. Hope this helps.
Old Dec 5, 2010 | 01:31 PM
BigWil's Avatar
Re: clutch install?
Broken link. http://www.zmydust.com/lt1clutch.html
Any chance of getting a copy of this?
Old Dec 5, 2010 | 04:45 PM
Re: clutch install?
Send a PM to Javier97Z28. He's still on the site, still a Moderator.
Old Dec 6, 2010 | 12:57 PM
sherwinZ28's Avatar
Re: clutch install?
http://web.archive.org/web/200802251...lt1clutch.html
I wish we could host these write ups on cz28.com...similiar to dsmtuners.com. I used this same write to do my clutch as well a few months ago.
Nov 18, 2023 07:21 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
