spragless?
Old Jan 17, 2007 | 10:13 AM
Lisa33's Avatar
spragless?
Have done some reading aboute the bennifits
http://www.transmission-specialties....x.php?cPath=22
Is there any downsides widh it on a "trailer queen"?
Old Jan 17, 2007 | 04:13 PM
mdacton's Avatar
Its is a key to run a tight package...I don't know how it works without one tho
Old Jan 19, 2007 | 12:30 AM
Lisa33's Avatar
Isnt it anybody who knows?
Running powerglide and 2650lbs raceweigt next year.
Old Jan 19, 2007 | 12:38 AM
Performabuilt's Avatar
Supporting Vendor
well there would be no free wheel for the trans downside would be more drag resistance and heat generated on coast bot the plus is definatly better et and lower loss through the converter
Old Jan 19, 2007 | 06:00 AM
Lisa33's Avatar
"downside would be more drag resistance and heat generated"
"plus is definatly better et and lower loss through the converter"
Thanks but i cant get this togheter If i get more drag resistance and building more heat, wouldnt that get me more loss in the converter?
Old Jan 19, 2007 | 08:09 AM
Supporting Vendor
drag resistance is only on decel not at throttle , normally with the sprag the converter turbines more or less get to free wheel when you are coasting but the will not spragless , So what I ment was you will generate more heat for instace rolling down a hill or decelerating not when you are accelerating.
Old Jan 19, 2007 | 02:33 PM
Lisa33's Avatar
OK that explaines "more heat", Can you also explaine how it will lead to lower ET? i belived that the sprag worked like a rollerbearing when you accelerate and i guess that the sprag is replaced widh a roller bearing in a "spragless" converter...
thanks...
Old Jan 19, 2007 | 02:36 PM
rskrause's Avatar
Moderator
Damn, a 'glide in a car as heavy as a 4th gen?? Curious as to how it works out. I'd go for a TH400 for sure. Let us know. I don't know sprags from spaghetti though, so I can't offer any thoughts on this one.
Rich
Old Jan 20, 2007 | 01:01 AM
Supporting Vendor
because the spragless never slips where sprags do
Old Jan 20, 2007 | 01:42 AM
Lisa33's Avatar
OK thanks
rskrause, as i wrote higher up in this thread "Running powerglide and 2650lbs raceweigt next year."
The LT1 will be in this http://www.nonameracing.se/photos/de...Projekt_Ascona next year.
(Weight properbly gonna be lower then 2650)
Old Jan 20, 2007 | 04:13 AM
rskrause's Avatar
Moderator
Makes sense at that weight. But I do wonder if it would be quicker with a 3-speed?
Rich
1badzee
Nov 21, 2011 10:52 PM
SPEED#1
May 14, 2010 07:05 PM
CANTONRACER
Feb 10, 2005 06:59 PM
